11.5 Web Viewer - Formatting Problems
Article ID: 141240
Updated On: 12-26-2019
Output Management Web Viewer
The job creates a tab-delimited file that is sent to CA VIEW.  The tabs are not working correctly in the new URL display of that file.
There was this problem before when there was a change to CA View,  and that you were able to change some formatting settings on the software.
Release : 11.5
Component : CA Output Management Web Viewer
There was a difference in the code page between the server that was working OK and the one (new) where the report browse at Page 8 was improperly formatted - no visible columns/tabs. Because the customer runs with DRAS Client Translation=ON, the Client/server based code page is used in report EBCIC to ASCII translation.
  1. Rename the attached file to 1252-1140.cp and put it in the Scripts folder of the Web Viewer r11.5 server
  2. the DRAS task's Set Client Translation parameter must be set to ON
IMPORTANT: Save this file to use in case a new install of Web Viewer 11.5 is done.  Repeat 1. and .2 above for the new server.
1575490736477__new_1252-1140.cp get_app
