AWA WORKLOAD_MAX_JOB and PREP_PROCESS jobs go into 'Waiting for Agentgroup'
Article ID: 141233
CA Automic Workload Automation - Automation Engine CA Automic Workload Automation - Automation Engine
When utilizing WORKLOAD_MAX_JOB in conjunction with PREP_PROCESS 'UNIXCMD' as part of a hostgroup (HOSTG), jobs will go into 'Waiting for Agentgroup'
This is caused by a logical error in calculation of resources at runtime in an Agentgroup
Release : 12.3
Component : AUTOMATION ENGINE
Workaround: Generate at Activation instead of Runtime
This has been resolved in 12.3.1 HF1
