This article provides tips on how to search for known Clarity articles, communities posts, and documentation.
STEP 1: Identify the problem
Including Errors from UI and logs to help in more in depth searching
See Clarity Debugging/Logs for troubleshooting - Master list of KB Articles
STEP 2: Search from the CA Support Broadcom portal
1. Log in to https://support.broadcom.com/enterprise-software
2. Enter search criteria and click enter
Example of screen shot of results below:
3. To search specially for KBs, click on the 'Filter by Content Type' drop down on the left hand side and select Knowledge Base
(By default, it searches all self service including knowledge articles, communities, documentation)
4. Note: You can also search from google, adding the following to your search string will help narrow this down to Clarity related KBs:
site:https://knowledge.broadcom.com/ clarity
Example search phrase:
site:https://knowledge.broadcom.com/ clarity msp caused a serious error
Tips:
Communities forum tip:
See the following post to utilize the communities to reach out to other customers and support engineers for help: Getting Started with Broadcom Communities
Notes:
