Data Engine not able to connect to the UIM database
Article ID: 141032
We have migrated the DB from one server to another, with a new IP address and  DNS name.
However, we are not able to connect the DB from Data_engine.
Test connection Error: Timeout occurred or communication error (-1).
Release : 9.0.2
Component : UIM - DATA_ENGINE
The issue was pertaining to the port configuration at DB server level.
The issue was resolved after this was corrected
