Changing what Automation Engine an Agent connects to
Article ID: 140680
CA Automic Workload Automation - Automation Engine
AUTOMIC WORKLOAD AUTOMATION
CA Automic One Automation
CA Automic Operations Manager
CA Automic Oracle
You want to take an existing OS Agent and direct it to connect to a new Automation Engine system
Release : 12.1
Component : AUTOMATION ENGINE
Within the agent's .ini file:
1.) Change the system= reference to point to the new system.
system=<OLD SYSTEM>
to
system=<NEW SYSTEM>
2.) Change the cp host/port the Agent is connecting to.
cp=<OLD IP>:2217
to
cp=<NEW IP>:2217
3.) Remove all entries listed under [CP_LIST] - these will be regenerated once the Agent connects to the new system..
Within the agent's bin folder on the OS:
1.) Delete the file ending in .kstr - this will be regenerated once the Agent connects to the new system.|
Feedback
