After running the post timesheet job I expect that any timesheet on an approved status gets posted.
However there is a spcecific timesheet that is not being posted. Why?
We need to look at the bg-ca.log file to understand what the cause is as those can vary
Please check the following KBs:
Unable to post a specific timesheet: ORA-01400: cannot insert NULL into ("CLARITY"."PPA_MATRIXCHECKOUT"."MATRIXKEY")
Unable to post a specific timesheet: ORA-01400: cannot insert NULL into ("CLARITY"."NBI_PROJ_RES_RATES_AND_COSTSCP"."TEAM_ID")
Unable to post a specific timesheet: ****POSTTIMESHEET: Couldn't post time entry
