We noticed that RC/Migrator generates IBM LOAD statements for a column defined as timestamp generated always. This leads to an error as IBM LOAD DB2 does not allow it and finishes with RC=08 and the following error message.
DSNU269I ]D12A 289 04:40:40.18 DSNURWUF - FIELD ROW_CHANGE_TSTMP IS NOT
ALLOWED
In the generated IBM LOAD statement there is a parameter IGNOREFIELDS YES.
Release:
Component:
