Problem accessing NFA console and sign-in getting redirected to https
Article ID: 137437
Updated On: 10-23-2023
Network Flow Analysis
Problem accessing NFA console sign-in and getting redirected to https
Observed after upgrade from NFA 9.5 to NFA 10.0.2
Using http and not https for logging into NFA console
Release : 10.0
Component : NQRPTA - REPORTERANALYZER
From the NFA_SSO.txt file in the RemoteEngineer can see the SsoSchme is set to https and SsoPort to 8382 instead of 8381
Also from the remote engineer logs the NFA_SSO.txt file has below entries and looks like below with local override set to https and port 8382
This will be set in  reporter.performance_center_properties table and dumped to the NFA_SSO file
Since using http and not https can use below script to reset back to http
Download the ApplyHTTPS.zip script from the article linked below
https://knowledge.broadcom.com/external/article?articleId=213529
Unzip the file and  select Run As Administrator from command line
Select the option to Apply http - option2
(Press '2' to setup HTTP.)
After this the NFA login will correctly default to http
