I was working on connecting to a new database via the SQL query operator. I used a connection string from a previous process and was getting errors. I changed the connection string to try and get it to use NTLM and started the process. A java dump was created in my c20/server directory multiple times and I ran out of disk space. I removed the dumps and restarted and the same happened again.
How do I kill that process so I can resume use of my machine with out dumping Java.
Release : 4.3
Component : Process Automation
Stop the orchestrator service.
Open oasisconfig.properties in the /c2o/.config folder and add the following line to the bottom of the file:
pam.disable.bootup.recovery=true
Restart the orchestrator and navigate to the operations tab and abort the process before it recovers and restarts.
