Problem with CA SYSVIEW FOR DB2 ARCHIVE job
Article ID: 13595
Updated On: 10-06-2023
SYSVIEW Performance Management Option for DB2 for z/OS
Archiving Histing Data and the load job fails S04E
Running the Archive job to unload Sysview for DB2 history and load it into DB2 tables, fails with an S04E.
And this message
DSNURWBG - INPUT FIELD 'OPT1ROWBLOCKSORT' NOT ENTIRELY WITHIN INPUT RECORD
UTILITY DATA BASE SERVICES MEMORY EXECUTION ABENDED, REASON=X'00E40323'
what could cause this?
z/os
The Unload job had the DB2VER parm set to 9.1 for DB2 V9 but the system is actually DB2 V10.
So set DB2VER to the version being used. So 10.1
   keith
