How to keep default value of 'Build Using Map' option in Endevor Quick Edit
Article ID: 135712
Endevor
When we change the value of the 'Build Using Map' option in Quick Edit to 'Y', exit Quick Edit, when go back in, the option is 'Y'. How do I make it reset back to 'N'?
To retain the default value of the Build Using Map feature, follow the steps below.
1. Review the Configuration Table .CSIQSRC(ENDICNFG) to ensure BUILD_USING_MAP=N.
2. Update the field QE_BUILD_MAP=ON  on the Options table .CSIQSRC(ENCOPTBL) is active. This will revert the Build Using Map back to 'N'.
