Problem with double encoding of OIDC state after upgrade to 12.8.02
Article ID: 133620
CA Single Sign On Secure Proxy Server (SiteMinder) CA Single Sign On Agents (SiteMinder) CA Single Sign On Federation (SiteMinder) CA Single Sign On SOA Security Manager (SiteMinder) CA Single Sign-On SITEMINDER
We're running CA Access Gateway (SPS), and implementing "Authorization
Endpoint Returns URL Encoded Response", we see that the response
gets double encoded :
The CA Access Gateway (SPS) gets Authorization request as :
   /affwebservices/myapp/oidc/authorize?SMASSERTIONREF=QUERY&response_type [...] &state=38271818-e3fe-4889-af3d-e2625cfee837%2COIDC
The CA Access Gateway (SPS) replies as :
  /commonauth? [...] &state=38271818-e3fe-4889-af3d-e2625cfee837%252COIDC
The state value gets double URL-encoded:
  Decoded ONCE: state=38271818-e3fe-4889-af3d-e2625cfee837%2COIDC
  Decoded TWICE: state=38271818-e3fe-4889-af3d-e2625cfee837,OIDC
So the API gateways is not be able to interpret this and understand
that it needs to doubledecode.
How can we fix this ?
Upgrade the CA Access Gateway (SPS) to version 12.8SP3 or 14.
