sds files corrupted at Proxy server
As first step please follow the next technical notes:
kb000010838 : Avoiding communication errors when configuring UIM components and improving tunnel stability for hub-to-hub tunnels
kb000072187: hub and tunnel connection settings in 7.x and 8.x
If problem persist after following these articles please do the following at Proxy Hub:
