I have upgraded to version 10.3.2 and report manager is not working. When I try the message of SRM has not finished starting appears.
Catalina.out shows the following errors:
2019-04-30 14:25:22,587 ERROR com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeUpdater - Error occurred while applying schema change
Name: 2017 (Product version: 10.3.2) - SRM Schema changes for pumping data to DOI
com.aprisma.spectrum.app.web.db.schemachange.FatalSchemaChangeException: com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeException: SPC-OCA-10067: Error occurred while running schema change script.Script: /spectrum/Install-Tools/rpmgr/sql/srm_schema_changes_for_doi.sql
10.03.02.PTF_10.3.204 resolves this problem.
REQUIREMENTS
SPECTRUM 10.03.00 and 10.03.02 are the prerequisites for installation of this patch.
This patch needs to be installed on just the OneClick SRM Server.
OVERVIEW
This is a PTF patch for the following issue:
DE412925 Details:
Symptom : Getting error Duplicate column name 'last_updated_time' in schema update after 10.3.2 upgrade and SRM not started.
Resolution: Added checks at the time of last_update_time column creation in srm_schema_changes_for_doi.sql.
(DE412925, 01339082)
BILL OF MATERIALS
ReleaseNote.PTF_10.3.204.txt
runme (Linux/Solaris)
uninstall_PTF_10.3.204.pl (Linux/Solaris)
runme.exe (Windows)
uninstall_PTF_10.3.204.exe (Windows)
srm_schema_changes_for_doi.sql (Windows)
Please contact support for a copy of this patch.
This 10.03.02.PTF_10.3.204 patch is NOT included in eutger the BMP (Bi-Monthly Patch) so if you install either of the bi monthly patches you will still need to install 10.03.02.PTF_10.3.204.
