Baseline _engine fails after several hours on linux
Article ID: 131651
DX Infrastructure Management NIMSOFT PROBES
baseline_engine probe suddenly get stopped with error:
 [  Thread-5]  WARN  queuemessengerimpl.QueueReaderImpl - The subscription to baseline_engine.QOS_MESSAGE is not ok. Resetting the subscription
[  Thread-5]  INFO  queuemessengerimpl.QueueReaderImpl - queue list not recieved from hub
[  Thread-5]  INFO  queuemessengerimpl.QueueReaderImpl - Queue baseline_engine.QOS_MESSAGE does not exist.
[  Thread-5]  ERROR impl.NimsoftApiImpl - NimSubscribe failure :(80) Session error, Unable to open a client session for [IP_ADDRESS]:48002: Connection refused
[  Thread-5]  ERROR impl.NimsoftApiImpl - .........subscribe for queue failed ..........
Also at _hub.log I can see:
[140666998101760] hub: ssl_server_wait - BIO error accepting connection
[140666998101760] hub: [1] error:0x02008018:system library:accept:Too many open files
file-descriptor-count setting at Operating System is not enough for the required load.
Linux RedHat
robot_update,"7.97HF3","656","Updates Nimsoft Robots to current version"
Hub 7.97 [Build 7.97.296 - hub: licIpCheck - 10.200.1.22
baseline_engine,"9.02","9.0.2-33","Baseline Engine"
prediction_engine,"9.02","9.0.2-20","Prediction Engine"
It is required that Opertating System Administrator the amount of open files allow by OS to the users (file-descriptor-count).
To see the settings for a user, as root issue the following commands:
su - <user that Run Nimsoft Hub daemons>
ulimit -n
The default setting for this is usually 1024. If more is needed for a specific user than as root modify it in the /etc/security/limits.conf file:
@user -nofile 2048
Will set the maximum open files for the specific "user" to 2048 files.
To do a system wide increase for all users as root edit the /etc/security/limits.conf file and add the following:
* - nofile 2048
This sets the maximum open files for ALL users to 2048 files. These settings will require a reboot to become active.
After performing the change verify that "ulimit -n" for the corresponding used was increased .
Note 1: Keep in mind that this way of configure Ulimit may variate depending the Unix/Linux version. Please adjust this setting with the Operating System Administrator.
Note 2: The command "lsof | wc -l " could help you determined the amount of file-descriptor-count required.
