Problem with admin console failing to load webservicemon probe configuration GUI
Article ID: 131394
DX Infrastructure ManagementNIMSOFT PROBES
When attempting to open the Admin Console version of the webservicemon probe GUI, an error occurs (PPM-001).
In the ppm log the following errors will be seen:
Apr 22 14:18:58:050 [attach_socket, ppm] Error while copying or loading adapter from jar file - Apr 22 14:18:58:050 [attach_socket, ppm] Failed to load or instantiate adapter com.nimsoft.ppm.adapter.webservicemon.Adapter
This is due to a defect in the webservicemon probe which will be fixed in release 1.33.
webservicemon 1.30 or 1.31 UIM 8.51 or higher
At this time, users should continue to use Infrastructure Manager to configure this probe until the webservicemon 1.33 probe is released which will resolve the issue and allow configuration to take place in Admin Console.
