Automation Engine hangs after clicking licenses in System Overview
Article ID: 130536
CA Automic Workload Automation - Automation EngineAUTOMIC WORKLOAD AUTOMATION
After 10 minutes all WPs report: U00003388 Connection to Server '<system>#WP<xxx>1' received no message for '600' seconds. ...and a PWP switich is trigger
During this time the Java Gui becomes (very) slow or even inaccessible.
Due to a correction in v11.2.9 to improve the license count the PWP get overloaded when thousands of agents are connecting to the Automation Engine
This issue only occurs in v11.2.9 and v11.2.10
Solution: Update to a fix version listed below or a newer version if available.
