using SQL function in FDM shows NULL results
Article ID: 130420
CA Test Data Manager (Data Finder / Grid Tools)
While trying to mask SQL columns in Fast Data Maker using SQL functions and you are seeing the Results as NULL
All supported versions of FDM
Make sure you un-check "Keep Nulls" for SQL Functions . Keeping NULL means that if target column have null values, keep them as is.
Feedback
