Need to add a load module to Endevor and the C1BM3000 job is not working correctly.
Article ID: 13015
Endevor Endevor Natural Integration Endevor - Enterprise Workbench Team Build Brightside Zowe
When trying to add a load module to Endevor the utility C1BM3000 is not working.  What has to be modified/added to allow a load module to be added to Endevor?
Release: All Supported Releases
There is no direct utility to allow you to add a load module to Endevor.  To do this multiple pieces that have to be modified:  the type definition, processor group definition and the processor that is called.
This is an example of a "LOADONLY"  Type definition.  Remember that this must be done for both stage 1 and 2.
DISPLAY ----------------------  TYPE DEFINITION  ------------------------------
COMMAND ===>
CURRENT ENV:  environ    STAGE ID:  1   SYSTEM:  system    TYPE:  LOADONLY
NEXT ENV   :  environ       STAGE ID:  2   SYSTEM:  system    TYPE:  LOADONLY
DESCRIPTION:  ===> INCLUDE TESTING
UPDATED:           28JUL06 13:57 BY ########
           -----------------  ELEMENT OPTIONS  -------------------
DELTA FORMAT(F/R/I/L) ===> F        SOURCE LEN   ===> 80         ELE RECFM(N/F/V) ===> N
COMPRESS/ENCRYPT(Y/N) ===> Y     COMPARE FROM ===> 1        DFLT PROC  ===> LOADONLY
AUTO CONSOL (Y/N)     ===> Y         COMPARE TO   ===> 80         LANGUAGE   ===> DATA
CONSOL AT LVL  ===> 96                 REGRESSION   ===> 50         PV/LB LANG ===> DATA
LVLS TO CONSOL ===> 50                REG SEV(I/W/C/E)  ===> I    DATA FORMAT(T/B) ===> T
HFS RECFM(COMP/CR/CRLF/CRNL/F/LF/NL/V)     ===> NL     FILE EXT   ===>
       -----------------  COMPONENT LIST OPTIONS  ------------------
FWD/REV DELTA(F/R)    ===> F  AUTO CONSOL (Y/N)      Y    CONSOL AT LVL       96
LVLS TO CONSOL      50
       -------------------------  LIBRARIES  -----------------------
BASE/IMAGE LIBRARY ===> iprfx.iqual.TEST.BASE1
DELTA LIBRARY          ===> iprfx.iqual.TEST.DELTA1
INCLUDE LIBRARY       ===>
SOURCE O/P LIBRARY ===> iprfx.iqual.SOL1
    EXPAND INCLUDES(Y/N)  ===> N
Define the processor group:
NEXT    ENV:  environ       STAGE ID:  2   SYSTEM:  system    TYPE:  LOADONLY
PROCESSOR GROUP:     LOADONLY      PROCESSOR O/P TYPE: LOADONLYLOADONLY
DESCRIPTION:         TESTCASE PROCESSOR
NEXT PRCS GROUP:     LOADONLY
UPDATED:             28JUL06 13:12 BY ########
-----------------------  OUTPUT MANAGEMENT INFORMATION  -------------------
PROCESSOR TO USE FOR MOVE           ACTION:     M (M/G)
PROCESSOR TO USE FOR TRANSFER     ACTION:     G (M/G)
       S - Browse Symbolics                    L - List Processor
                                   FOREGROUND EXECUTION
 GENERATE PROCESSOR:     LOADONLY     :     Y (Y/N)
 DELETE PROCESSOR:       *NOPROC*     :     Y (Y/N)
 MOVE PROCESSOR:         LOADONLY     :     Y (Y/N)
This is the processor that will be used in both the add and move processors.
//**   LOAD MODULE PROCESSOR FOR THE GENERATE                  **
//LOADONLY  PROC  LOADSRC='iprfx.iqual.LOAD',
//                LOADTGT='iprfx.iqual.LOADLIB1',
//                LISTSRC='iprfx.iqual.LISTING',
//                LISTTGT='iprfx.iqual.LISTING1',
//                PGM=BSTCOPY
//INIT  EXEC  PGM=BC1PDSIN
//C1INIT01    DD  DISP=(,PASS),DSN=&&COPYOUT,
//            UNIT=SYSDA,SPACE=(TRK,(1,1)),
//            DCB=(RECFM=FBA,LRECL=121,BLKSIZE=6171,DSORG=PS)
//SYSPRINT    DD  SYSOUT=*
//SYSOUT      DD  SYSOUT=*
//IF1   IF  ((&C1ACTION=ADD) OR (&C1ACTION=UPDTE)) THEN
//ADD     EXEC PGM=&PGM
//SYSUT3      DD  UNIT=SYSDA,SPACE=(TRK,(1,5))
//SYSUT4      DD  UNIT=SYSDA,SPACE=(TRK,(1,5))
//INDD        DD  DSN=&LOADSRC,DISP=SHR
//OUTDD       DD  DSN=&LOADTGT,DISP=SHR
//SYSIN       DD  *
COPY O=OUTDD,I=INDD
SELECT MEMBER=((&C1USRMBR,&C1ELEMENT,R))
//END1  ENDIF
//IF2  IF ((&C1ACTION=TRANSFER) OR (&C1ACTION=MOVE)) THEN
//TRANSFER EXEC PGM=&PGM
//SYSPRINT    DD  DSN=&&COPYOUT,DISP=(OLD,PASS)
//SYSIN       DD  *
COPY O=OUTDD,I=INDD
//END1  ENDIF
The way this works is the load library member is analyzed and the information from that member is then added into Endevor Base/delta as the source code.
After the source has been added the processor is then run to move or add the load module into a controlled Endevor load library.
