CA Output Management Document ViewerCA Output Management Web Viewer
There is a problem with CA OM Web Viewer help panel not working, when selectin that option a new browser windows pop up but is blank. https://mainframei.manulife.com:8443/CAOMWebViewer12/popupHelp.jsf?loc=default Build 179
The Chrome and Firefox browsers are not supported for CA OM Web Viewre
IE 11 Chrome Firefox
Use IE 11. That is the only currently supported browser.
