CA PanAudit PlusCA Easytrieve Report GeneratorCA PAN/SQL
Why could there be a different alignment of columns in REPORTs between 6.4 and 11.6?
Release: Component: EZTRVE
With CA Easytrieve release 6.4 (and very likely with former releases too) the alignment was calculated based on the LRECL of the SYSPRINT DD. Since release 11.0 and upwards the alignment will be calculated based on the LINESIZ value in the EZOPTBL options table, or LINESIZE in the REPORT or FILE statement. For example, when only changing //SYSPRINT DD SYSOUT=* to //SYSPRINT DD SYSOUT=*,RECFM=FBA,LRECL=141 in both releases, then the alignment in the REPORT will be changed for release 6.4. But there will be no change in 11.6. First when changing LINESIZ from 132 to 141 in the 11.6 EZOPTBL, you will see the same alignment like with 6.4 and LRECL=141.
That works as designed - the alignment calculation should base on LINESIZ and not on LRECL of the SYSPRINT DD.
