problem login to SOI after fail over to secondary manager server
Article ID: 129454
CA Service Operations Insight (SOI)
Unable to login to SOIUI after failing over the cluster node from active to passive
- The SOI manager java process was still running on the cluster node the manager was failed from - DbAvailHistory, DbRiskHistory and DbQualityHistory each had around 400 million rows of data.
- From cluster manager offline all SOI services and killed the java process on the passive node - Used SQL scripts from KB000129125 to purge the data - Also ran following queries to purge data delete from CIHealth where endPeriod is null and CIID not in (select CIID from CI where ClassID=5) delete from CIRisk where endPeriod is null and CIID not in (select CIID from CI where ClassID=5) delete from CIQuality where endPeriod is null and CIID not in (select CIID from CI where ClassID=5)
delete from DbAvailHistory where ServiceID not in (select CIID from CI where ClassID=5) delete from DbRiskHistory where ServiceID not in (select CIID from CI where ClassID=5) delete from DbQualityHistory where ServiceID not in (select CIID from CI where ClassID=5) - From cluster manager online all SOI services
