ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
system agent jobs using #NOX control cards
Article ID: 129100
CA 7 Workload Automation
If we get an adhoc request to make the next run of a system agent job non executable, can we use the #NOX control card like we do with mainframe batch jcl jobs?
Release: Component: 7
Yes, you can make an agent job non executable by putting #NOX in the PARMLIB member and saving it out to the override library. This will cause the USE-OVRD-LIB field to be set to Y and therefore when the job enters the request queue it will pull the PARMLIB data from the override library. The #NOX will be detected and the the job will be marked non executable.
