MCS errors - After removing 1 system from a group, it did not remove the MCS profile configuration.
Article ID: 128824
DX Infrastructure Management NIMSOFT PROBES
- Some profiles do not delete and display with a Red "X"
- After removing a system from a group, the MCS configuration was not removed
- assorted
- UIM 8.5.1
WARNING: Be careful when running delete statements. We highly recommend testing any database table changes in a Test/DEV environment first.
This query will return the name of the device that has profiles displaying a red cross (error state):
   select name from CM_COMPUTER_SYSTEM where cs_id IN (select cs_id from SSRV2profile where status = 'error')
select * from ssrv2audittrail where objectid=636726
--shows the status of the MCS request to delete a profile
select * from ssrv2profile where profileid=636726
--shows the status of the profile, e.g., shows IF the MCS profile was deleted.
---> Note that the Profile ID is visible at the bottom of the Monitoring Tab->MCS profile page.
If you ->>> set retries = 0 it will try to delete it again
--to check the retries state
Via the USM Monitoring Tab try to delete the profile again via USM by clicking on the trash can icon.
Run the queries again and check the status:
--shows the status of the request
select * from ssrv2profile where status = 'error'
--shows profiles that ended in an error state
You can use 'where profileid in (profileid1, 2, 3)' for multiple profiles
in USM, if the Profiles' Red X disappears it means MCS is again trying to delete the profiles in the background.
select * from ssrv2profile where ancestorprofile=636726
--check the status of the deletes
select * from ssrv2profile where cs_id in (Select distinct cs_id from ssrv2profile where ancestorprofile in (636726, 639969, 637222)) and status != 'ok' and retries > 28;ancestorprofile=636726
Set the status to 'modified' and change retries to 0 so MCS ((mon_config_service), will try and delete the profile again.
update SSRv2profile set retries = 0, status = 'delete' where profileName in ('LogicalDiskFreeMB_C', 'LogicalDiskFreeMB_E' ProcessorTime_Total')
--To delete profiles manually based on 'ProfileName'
--To retry a deployment, run the update and set the retries to 0 and the status to modified.
Other tasks that should be completed to resolve the issues:
- Deploy mon_config_service-8.5.8-HF14.zip
- Deploy nis_server-8.5.1-HF1.zip
- Deploy attr_publisher package v7.97 (Upgrade all robots to attr_publisher 7.97, which fixed ~80% of the errors.)
- Resolve any related robot/system correlation issues
