SRM has not finished starting - schema 2014 failed
Article ID: 128028
Spectrum Network Observability
After upgrading there is "SRM has not finished starting" message.
When reviewing the log files, the following error is seen:
Feb 24, 2019 06:38:59 AM (SRM/Startup/Container) (com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeUpdater) - (ERROR) - Error occurred while applying schema change
  Name: 2014 (Product version: 10.3.0) - Jasper Multi-teancy changes.
com.aprisma.spectrum.app.web.db.schemachange.FatalSchemaChangeException: com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeException: SPC-OCA-10067: Error occurred while running schema change script.Script: e:\win32app\Spectrum\Install-Tools\rpmgr\sql\multi_tenancy_changes.sql
	at com.aprisma.spectrum.app.web.db.schemachange.BaseSchemaChange.applySchemaChange(BaseSchemaChange.java:193)
	at com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeUpdater.applySchemaChange(SchemaChangeUpdater.java:95)
	at com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeUpdater.doApplyChanges(SchemaChangeUpdater.java:201)
	at com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeUpdater.applyChanges(SchemaChangeUpdater.java:142)
	at com.aprisma.spectrum.app.web.db.schemachange.BaseSchemaChangeManager.runUpdater(BaseSchemaChangeManager.java:195)
	at com.aprisma.spectrum.app.web.db.schemachange.BaseSchemaChangeManager.applyChanges(BaseSchemaChangeManager.java:136)
	at com.aprisma.spectrum.app.repmgr.dc.db.changes.SRMSchemaChangeRunner.runChanges(SRMSchemaChangeRunner.java:53)
	at com.aprisma.spectrum.app.repmgr.dc.db.ReportManagerInitializer.init(ReportManagerInitializer.java:74)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleElement.invoke(InitDestroyAnnotationBeanPostProcessor.java:349)
	at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleMetadata.invokeInitMethods(InitDestroyAnnotationBeanPostProcessor.java:300)
	at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:133)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1560)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:540)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:476)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:302)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:229)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:298)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1471)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1216)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:538)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:382)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:157)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:743)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:757)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:480)
	at com.ca.spectrum.app.web.spring.BootstrapServlet$ContainerStartupProcess.refreshContainer(BootstrapServlet.java:250)
	at com.ca.spectrum.app.web.spring.BootstrapServlet$ContainerStartupProcess.run(BootstrapServlet.java:208)
	at java.lang.Thread.run(Thread.java:748)
Caused by: com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeException: SPC-OCA-10067: Error occurred while running schema change script.Script: e:\win32app\Spectrum\Install-Tools\rpmgr\sql\multi_tenancy_changes.sql
	at com.aprisma.spectrum.app.web.db.schemachange.InstallScriptSchemaChange.runScript(InstallScriptSchemaChange.java:89)
	at com.aprisma.spectrum.app.web.db.schemachange.InstallScriptListSchemaChange.doSchemaChange(InstallScriptListSchemaChange.java:71)
	at com.aprisma.spectrum.app.web.db.schemachange.BaseSchemaChange.applySchemaChange(BaseSchemaChange.java:185)
	... 102 more
Caused by: com.aprisma.util.mysql.ScriptRunnerException: Error occurred while running SQL script.
  Script: e:/win32app/Spectrum/Install-Tools/rpmgr/sql/multi_tenancy_changes.sql
	at com.aprisma.util.mysql.SQLScriptRunner.runScript(SQLScriptRunner.java:162)
	at com.aprisma.util.mysql.SQLScriptRunner.runScript(SQLScriptRunner.java:134)
	at com.aprisma.spectrum.app.web.db.schemachange.InstallScriptSchemaChange.runScript(InstallScriptSchemaChange.java:83)
	... 104 more
Caused by: com.aprisma.util.mysql.ScriptRunnerException: Error occurred with SQL Script
  Stdout:
  Stderr:
mysql: [Warning] Using a password on the command line interface can be insecure.
ERROR 1060 (42S21) at line 26 in file: 'e:\win32app\Spectrum\Install-Tools\rpmgr\sql\multi_tenancy_changes.sql': Duplicate column name 'jasperMultiTenancyEnabled'
Release:
Component: SPCRPT
NOTE: In the following MySql commands, replace <PASSWD> with the root password for your DX NetOps Spectrum version.
1. Log into the Spectrum Report Manager system as the user that owns the Spectrum installation
2. If on Windows, start a bash shell by running "bash -login"
3. cd to the $SECROOT/mysql/bin directory and enter the following command to log into mysql:
$ ./mysql --defaults-file=../my-spectrum.cnf -uroot -p<PASSWD> reporting
4. Enter the following command at the mysql prompt:
mysql> update schemaversion set state='A' where name='2014';
5. Type exit at the mysql prompt
6. Restart tomcat on the SRM system
7. Review the $SPECROOT/tomcat/logs/stdout.log (Windows) or catalina.out (Linux) file for the error.
