UIM - Reset MCS monitoring (Monitoring configuration Service)
Article ID: 12764
Attention: Going through the steps of the Article will completely reset MCS and all monitoring profiles will have to be recreated manually.
Can we reset MCS monitoring as I have some issues with profiles? This KB Describes how to reset MCS Monitoring tables.
Release: UIM 8.x, 9.x
Follow the steps below to reprocess the MCS templates and repopulate the SSRV2Template db table.
UIM 8.x and earlier
  1. Deactivate mon_config_service probe
  2. Copy SSRV2_drop_all_tables.sql and Create_SSRV2_tables.sql under $Nimsoft\probes\service\mon_config_service\scripts\database\<your_DB_type> folder to DB server and run the scripts
  3. Activate the mon_config_service probe
  4. Delopy mon_config_service probe_templates from Archive
  5. Create and deploy a profile under Monitoring tab in USM
UIM 8.51 and later
  2. Browse to the Nimsoft\probes\service\mon_config_service\lib directory
  3. Copy the mcs-db-scripts.jar file to the desktop.  (Make sure you do not move this file)
  4. Rename the file to mcs-db-scripts.zip.
  5. Open the ZIP file and extract the following files (\mcs-db-scripts.zip\legacy\sqlserver or mysql or oracle, depending on the UIM database in use):
    1. SSRV2_drop_all_tables.sql
    2. Create_SSRV2_tables.sql
  6. Copy the two .sql files to DB server and run the scripts to drop and then create the table structure (right-click on each file > Open With > Keep using SQL Server Management Studio). If any table cannot is not removed by the query, please remove them manually.
  7. Run the following SQL command: DROP TABLE SSRV2SchemaMigration;
  8. Activate the mon_config_service probe
  9. Deploy mon_config_service probe_templates from Archive Eg. cdm_mcs_templates, processes_mcs_template, net_connect_mcs_templates etc.
  10. Create and deploy a profile under Monitoring tab in USM
UIM 9.02 and later
  5. Open the ZIP file and extract the following file ONLY (\mcs-db-scripts.zip\legacy\sqlserver or mysql or oracle, depending on the UIM database in use):
  6. Copy the .sql file to DB server and run the script to drop the table structure (right-click on the file > Open With > Keep using SQL Server Management Studio). If any table is not removed by the query, please remove them manually, e.g., via Rt-Click->Delete for each leftover SSRV2 table by using the MS SQL Server Studio or another database vendor tool.
  7. Activate the mon_config_service probe - it will create the needed tables automatically.
  8. Deploy mon_config_service probe_templates from Archive. Eg. cdm_mcs_templates, processes_mcs_template, net_connect_mcs_templates etc.
  9. Create and deploy a profile under Monitoring tab in USM
NOTE
If working on Oracle and using either SQL*Plus or SQL Developer you need to run
SQL> set define off;
before you run the script to avoid an issue with a label containing the & character. see here for an explanation.
this process was also used to solve the below error in the MCS logs:
Mar 18 11:08:51:698 [main, mon_config_service] com.microsoft.sqlserver.jdbc.SQLServerException: The statistics 'poller' is dependent on column 'poller'.
Mar 18 11:08:52:205 [1352] Controller: Max. restarts reached for probe
Also, for UIM 9.01EA, due to an issue with the V9_0_0_00__Add_SSRV2PolicyProfileBlob_Table.sql migration script added in (.01 EA, after executing the SSRV2_drop_all_tables.sql make sure you also drop the following before executing the Create_SSRV2_tables.sql script:
Tables:
SSRV2PolicyTargetStatus
Sequences:
SSRV2PolicyProfileBlob_seq
SSRV2PolicyTargetStatus_seq
Triggers:
SSRV2PolicyProfileBlob_seq_tr
SSRV2PolicyTargetStatus_seq_t
Note regarding MySQL (Upgrade from UIM 8.5.1 to 9.0.2 with MySQL v5.7)
- If the reset of MCS does not resolve the issues being see with mon_config_service, e.g., not starting, please also check this article:
MCS (mon_config_service) monitoring stopped working after upgrading UIM from 8.5.1 to version 9.0.2
https://ca-broadcom.wolkenservicedesk.com/external/article?articleId=125623
NOTE FOR UIM 9.2.0:
After running the "Drop All Tables" script you should run the following queries in order:
Sequences
drop sequence SSRV2PROFILEEVENT_SEQ;
drop sequence SSRV2POLICYPROFILEBLOB_SEQ;
drop sequence SSRV2POLICYTARGETSTATUS_SEQ;
Tables
drop table SSRV2CONTAINERPROPERTY;
drop table SSRV2POLICYPROFILEBLOB;
drop table SSRV2PROBETEMPLATEUPGRADE;
drop table SSRV2PROBETEMPLATESPACKAGE;
drop table "SSRV2SchemaMigration";
drop table SSRV2TEMPLATEFILTER;
drop table SSRV2PROFILECONDITION;
drop table SSRV2POLICYTARGETSTATUS;
drop table SSRV2PROFILEEVENT;
Views
drop view SSRV2GROUPWITHPATH;
After this, verify all tables and sequences beginning with SSRV2 are gone from the database and manually delete any leftovers.
IMPORTANT!
Make sure ALL SSRV2 Tables, Sequences, Functions, Triggers, and/or Views have been dropped, otherwise you will not resolve template problems showing up as XML, or templates becoming grayed out, or errors such as-> [main, mon_config_service] org.flywaydb.core.api.FlywayException.
To confirm all of the mon_config_service tables have been dropped, check using this query for Oracle databases:
select * FROM USER_OBJECTS WHERE OBJECT_NAME LIKE '%SSRV%'
select * from ssrv2template -> will show you which templates were processed and when they were processed.
Note that once the MCS is reset/the tables are dropped you must follow this sequence:
- Deactivate mon_config_service
- Delete it from the file system
- Redeploy it
- Redeploy the mcs_template probe packages to the Primary Hub from the local archive
- Activate mon_config_service
- Wait around 10-15 minutes then check
