Problems running sample EP agent plug-in on APM IA
Article ID: 125573
APM CA Application Performance Management Agent (APM / Wily / Introscope) DX Application Performance Management DX Application Performance Management DX SaaS
We have installed the APM Infrastructure agent on our application server and upon that deployed the EP agent sample plugins but these are failing and we get the following format errors in thelog file
1/28/19 10:40:50 AM GMT [ERROR] [IntroscopeAgent.EPAgent HTTP] [ stderr ] Can't open perl script "C:\apm": No such file or directory
The definition in the bundle.properties has the script defined as follows
introscope.epagent.stateless.EpaSamples.HTTP.command=perl {ApmExtensionHome}\\bin\\httpSvcAvailability.pl -url http://www.yahoo.com
The expansion of {ApmExtensionHome} is not able to handle spaces in the path - the APM IA  in this case was installed in "C:\apm ia"
APM IA 10.7 Windows
The APM IA must be installed in a location that does not contain spaces in the full path - a defect has been raised for this restriction to be addressed
No other workardounds have been identified - enclsong the path in quotes does not help
