Ax32.exe is not reporting to the investigator - there is a native profiler log but no other logs - AX32serv.exe is reporting.
It appears this is not a .Net application as it is not loading any .Net dlls such as mscor* type dllsTasklist /m showed that the AX32.exe process was only loading the following DLLs
