Problem with Endevor/Carma bridge
Article ID: 124128
Updated On: 01-22-2019
Endevor Endevor Natural Integration Endevor - ECLIPSE Plugin Endevor - Enterprise Workbench
Problem with CARMA bridge during IDZ testing when trying to "cast an Endevor package". Why are we seeing errors in the Endevor log.
PKMR120E PACKAGE <pkg_id> IN USE AND NOT AVAILABLE AT THIS TIME
The Endevor exit, ENUXSITE, is in use.
Release:
Component: ENDBAS
Need to contact IBM for the CARMA bridge connection issue.
Rewrite ENUXSITE to remove problematic behavior and upgraded CARMA to latest release ( IBM IDz v14.1.5 PTF UI60051).
