Maximum block size for input and output files
Article ID: 12192
Updated On: 10-13-2023
Easytrieve Report Generator PAN/SQL
Has the maximum block size for input and output files for CA Easytrieve release 11.6 changed from release 6.4?
CA Easytrieve Report Generator, release 11.6
The maximum block size for input and output files is still 32,767.  This limit has not changed from release 6.4.
