CA Threat Analytics for PAMCA Privileged Access Manager - Server Control (PAMSC)CA Privileged Access Manager (PAM)CA Privileged Identity Management Endpoint (PIM)
You can find different issues to use SSH with x11 in PAM
PAM 3.2.0 Accessing Linux OS with X11 Xmind application or ReflectionX as Xserver in the windows station Windows Station connecting via NAT to network of PAM server and where are the servers
Cause1) After opening the ssh session with x11 enabled checking the variable $DISPLAY this is blank. Cause2) trying open xclock from SSH session and getting errors:
X11 connection rejected because of wrong authentication. X connection to localhost:11.0 broken (explicit kill or server shutdown)
or this error:
Xlib: connection to "localhost:12.0" refused by server Xlib: PuTTY X11 proxy: Authorisation not recognised
For cause1 when variable $DISPLAY is showing as blank, sounds ssh session is not opened with -X flag. Check this points:
1) You can edit the device uncheck the x11 apply the modification, enabling the checkbox again and saving again and test to see if works; 2) Check if xorg-x11-apps is instaleld on the Linux device. These tools are useful to test for example 'xclock'
rpm -q xorg-x11-apps' returns the message: "package xorg-x11-apps is not installed".
you can ask Unix administrator to install using root user and rpm command if this is not installed or the user does not have access to check it.
3) Check on linux server if have X11 ports 60100 for example. command line: netstat --listen | grep 60100 (an example if x11 is using port 60100)
For cause 2 when errors related to "wrong authentication" and X11 connection being rejected or trying outside PAM also getting error "refused by server" use this steps for use case where you have a ssh session opened with a generic user and do a sudo su to oracle user for example to install oracle or run xclock as oracle user.
