Remote Control to agent machine not working. Repository does not get populated after selecting the Stealth View. RC status in ITCM explorer shows " Not Listening " .
Article ID: 11760
CA Client Automation
While trying to take Remote control of agent machine from Viewer not working.
Repository not getting populated after selecting the connection method "stealth view" .
RC Status of the machine shows " Not Listening" .
 Why is Remote Control to an Agent not working ?
 Why does the Repository not get populated after selecting the Stealth View ?
Why is the RC status in DSM Explorer showing "Not Listening ?
ERROR:   Address is valid, but the connection was rejected.
Please check that the remote control host is running , and listening for connections
CA Client Automation - All Versions
Check TRC_URC_HOST_0.log   for the below errors:
080816-15:45:37.8293653L|004620|00000ccc|HOST |mxGetPmuxPort |CPmuxAPI.cpp |000679|INFO | Leaving, pmux port = 4728
080816-15:45:38.8933372L|004620|00000ccc|HOST |mxOpenPmux() |CPmuxAPI.cpp |000920|INFO | Unable to establish connection to the PMUX service. The service may not be running
080816-15:45:38.8934622L|004620|00000ccc|HOST |CCFPmux::Listen |CCFPmux.cpp |000150|INFO | Pmux was unable to start listener
080816-15:45:38.8935136L|004620|00000ccc|HOST |cfNetwork |CCFNetServer.cpp |000214|ERROR | CCFNetServer::Listen: Protocol unable to listen for connections
080816-15:45:38.8935591L|004620|00000ccc|HOST |rcHost | |000000|INFO | CRCListeners::AddListener: ERROR: protocol TCP: failed to listen
1. Execute Below commands and check RC Status in ITCM Explorer changing to " Listening"
please check 'csampmux status' and check system variables and  the PATH as well:
Variable:
CSAM_LOGGER_CONF=C:\Program Files (x86)\CA\SC\Csam\SockAdapter\cfg\logger.cfg
CSAM_SOCKADAPTER=C:\Program Files (x86)\CA\SC\Csam\SockAdapter\
PATH
CA\SC\CBB\;C:\Program Files (x86)\CA\DSM\bin; C:\Program Files (x86)\CA\SC\Csam\SockAdapter\bin; C:\Program Files (x86)\CA\SC\Csam\SockAdapter\bin64
2. Perform the following steps :
1. CAF STOP
2. Caf setprop pmux installed 0
3. Caf disable pmux
4. csamconfigedit PmuxEmulateDSMProtocol=True PmuxDSMServerPort=4728
5. cam change disabled
6. camclose
7. csampmux stop
8. cam change auto
9. CAF START
Above steps may resolve issue's in most cases if there is no problem with csampmux files in directory:
  ...CA\SC\CSAM\SockAdapter
There will be a Error at step 4 if files & Directories in SockAdapter folder are missing .
'csamconfigedit' is not recognized as an internal or external command,
operable program or batch file.
Check csampmux status and see if you have below mentioned ERROR.
log4cplus:ERROR No Appender could be found for logger <CSAM.BROK>
log4cplus:ERROR Please initialize the log4cplus system properly.
3. Check the files and directories on working and non working machine under below path.
Stop the services on agent and Replace the directories\Files  from working machine with same version, in case if there is a difference between working and non working machine .
Start the Caf after replacing the directories.
Note : Open a ticket with Support if above mentioned troubleshooting did not help.
