DIFFERENCE BETWEEN CLASS1 CPU AND CLASS2 CPU REDUCED SIGNIFICANTLY
Article ID: 116883
Bind Analyzer for DB2 for z/OS SQL-Ease for DB2 for z/OS SYSVIEW Performance Management Option for DB2 for z/OS Plan Analyzer for DB2 for z/OS Subsystem Analyzer for DB2 for z/OS
After applying  maintenance which contained PTF RO97230 the difference between  Class1 CPU (APPL_TCB) and Class2 CPU (DB2_TCB) is reduced compared with the prior days in most of the batch jobs. What could be the cause of this difference in the reporting?
Release:
Component: CIDB
PTF RO97230 has changed the way the product compute these times. Theses times are computed via single routine commom for Sysview for Db2.
The difference is caused by this PTF RO97230 DESCRIPTION = APPLICATION TCB TIME IS REPORTED INCORRECTLY .
