Napatech and system clock will not sync after force
Article ID: 116756
CA Application Delivery Analysis MTP (NetQoS / ADA)
Errors on the VMTP state that the Napatech and system clocks are not within 5 minutes of eachother.
After running:
/opt/NetQoS/scripts/syncNapatechClock --force
We see no change in time discrepancy
CentOS 6.X
During the 11.0 VMTP upgrade, the Napatech drivers were changed and some of our NetQoS scripts were not updated to reflect these changes.
The nqcapd processes would not start due to their internal clocks not being within 5 minutes of the system clock. This is a defect in 11.0.2 that is remedied by editing the syncNapatechClock script
1) 'nano /opt/NetQoS/scripts/syncNapatechClock'
2) Locate the following line:
if [ "`/sbin/lsmod | /bin/grep ntki`" != "" ] ; then
change it to the following:
if [ "`/sbin/lsmod | /bin/grep nt3gd`" != "" ] ; then
3) Save and Exit
4) Execute the Napatech sync and monitor for drift:
sudo /opt/NetQoS/scripts/syncNapatechClock --force
