SNMPv3 Devices Not Showing in NetOps Performance Management
Article ID: 116749
Updated On: 12-17-2024
CA Performance Management Network Observability
  • Devices are configured properly but still not showing properly in DX NetOps Performance Management.
  • The device names are showing as IP instead of device name.
  • Device type showing as pingable instead of switch, router, etc.
DX NetOps Performance Management Data Aggregator fails to discover device using SNMPv3.
The correct SNMP Profile is in use but it's failing to discover the device.
All supported DX NetOps Performance Management Data Aggregator releases
After enabling debug for discovery, the following Warning messages appear in the karaf.log from the Data Collector. This indicates that a bad user name is being passed to the target device.
2018-09-28 12:15:11,300 | INFO  | tory-thread-8172 | IcmpDiscoveryRunner              | mp.collector.IcmpDiscoveryRunner   73 | 197 - com.ca.im.data-collection-manager.icmp.collector - 3.5.0.RELEASE-191 |  | Starting ICMP range discovery for 1 ip addresses
2018-09-28 12:15:11,305 | INFO  | xecutor-thread-2 | IcmpDiscoveryRunner              | mp.collector.IcmpDiscoveryRunner  219 | 197 - com.ca.im.data-collection-manager.icmp.collector - 3.5.0.RELEASE-191 |  | ICMP range discovery complete with 1 responding IPs.
2018-09-28 12:15:11,306 | WARN  | Response Pool.0  | TooBigListener                   | dm.snmp.collector.TooBigListener  279 | 196 - com.ca.im.data-collection-manager.snmp - 3.5.0.RELEASE-191 |  | TooBigListener received non response PDU.  Sending timeout ResponseEvent to original response listener.  Original Response Event:ResponseEvent [source=ReportProcessor, address=<DeviceIP>/161, request=GETNEXT[{contextEngineID=80:00:1f:88:16:7e:1f:8e:7e, contextName=}, requestID=918186017, errorStatus=0, errorIndex=50, VBS[1.3.6.1.2.1.1.3 = Null]], response=REPORT[{contextEngineID=80:00:1f:88:03:cc:16:7e:1f:8e:7e, contextName=}, requestID=0, errorStatus=0, errorIndex=0, VBS[1.3.6.1.6.3.15.1.1.3.0 = 153489]], userObject=SnmpV3Profile [profileId=4740@161, name=Test2, rank=4, authProtocol=MD5, privProtocol=AES128, userName=<encryptedString>
, authPassword=<encryptedString>
, privPassword=<encryptedString>
], error=null], original request:AsyncSnmp4jRequest [request=Snmp4jRequest [target=UserTarget[address=<DeviceIP>/161,version=3,timeout=3000,retries=2,securityLevel=3,securityModel=3,securityName=4740@161,preferredTransports=null, authoritativeEngineID=], pdu=GETNEXT[{contextEngineID=80:00:1f:88:16:7e:1f:8e:7e, contextName=}, requestID=918186017, errorStatus=0, errorIndex=50, VBS[1.3.6.1.2.1.1.3 = Null]]],
    listener=com.ca.im.dm.snmp.collector.SnmpProfileDiscoveryTask@4adcb7f,
Ensure the SNMP Profile used for Discovery contains the correct credentials.
OID for usmStatsUnknownUserNames is 1.3.6.1.6.3.15.1.1.3.
The following debug was used to determine the cause. Take these steps to enable the discovery debug on the DC host discovering the device.
  1. Navigate to the following directory (default paths shown):
    • /opt/IMDataCollector/apache-karaf-2.4.3/etc
  2. Make a backup copy of the original configuration file:
    • cp org.ops4j.pax.logging.cfg org.ops4j.pax.logging.cfg_Orig
  3. Edit the org.ops4j.pax.logging.cfg file adding the below entries. If already added to the file ensure they are uncommented to enable them.
  4. Save the file which activates the debug. No restarts are needed.
log4j.logger.com.ca.im.dm.snmp.collector.SnmpProfileDiscoveryTask=debug
log4j.logger.com.ca.im.dm.snmp.snmp4j.USMProxy=DEBUG,sift
log4j.additivity.com.ca.im.dm.snmp.snmp4j.USMProxy=false
log4j.logger.com.ca.im.dm.snmp.snmp4j.MPv3Proxy=DEBUG,sift
log4j.additivity.com.ca.im.dm.snmp.snmp4j.MPv3Proxy=false
