Issue with 2 same Custom Attributes into Access Roles
Article ID: 113716
CA Identity ManagerCA Identity GovernanceCA Identity Portal
The "Modify Access Role" admin task is defined with custom fields into the profile tab screen.
When Submitting a Modify Access Role with 2 custom fields with an identical value (x) then it fails as following: Error: [Profile] Custom Field value "x" is not unique.
IM r14.x.
You need to set the "Allow duplicate values in custom fields" checkbox into the Profile tab before submitting the Modify Access Role task.
