Is it possible to have a distributed installation with the Automic Workload Automation Server or Automation Engine hosted on Linux and the Automic Database on MS SQL Server (MSSQL) hosted on Windows?
In certain environments, it may be a policy to restrict Application installation on Database Servers. Is the above distributed installation supported?
Automic Workload Automation Database installation on MS SQL Server hosted on Windows and Automic Automation Server/ Automation Engine hosted on Linux is not a supported configuration.
Automic Workload Automation Server/Automation Engine needs to be installed on Windows as well.
