Reports are not running with connection failure message
Article ID: 112474
CA Service Management - Asset Portfolio ManagementCA Service Management - Service Desk Manager
Customer is not able to run the reports in CABI. They are failing from CA Reports and custom reports. He gets a kind of message:
2018-08-22 14:24:34 com.businessobjects.report.web.shared.WebReportingException: The viewer could not process an event. Failed to open the connection. <Report Name> [] ---- Error code:0 [CRWEB00000119]
The ODBC Data Access Service were corrupted
CA Service Desk Manager 14.1
Activities to ensure that all the environment is correctly configured:
. we check the odbc configuration in the CABI Designer. The test the odbc connections from Service desk side 32bit and CABI side 64bit connections and all were failed . Checked the User Preferences in the BI Launch PAD for the Cabi user that is trying to run the Report, and set the locale to English . Checked the CCM processes and all those were up and running. . Checked the ODBC Agent and Data Access Services to ensure that they are up and running, however the ODBC Data Access was corrupted
- To solve it, customer manually killed the oasoa.exe process in the Task Manager in Service Desk Serve Went in the %NX_ROOT\add-ons\tracing and deleted the all files from this folder.
. Restarted the ODBC Data Access and ODBC Agent services . Restarted the Tomcat and SIA in CABI Server . tested the ODBC from Service Desk Server side 32bit and CABI Server side 64bit connections and all were OK now . The Reports ran successfully
