Setting up the Extensioble Socket Connector Assertion: After installing the "Extensible Socket Connector" Tactical Assertion (it is described fairly well in the documentation that comes with it). We then setup the policy as follows :
We manage our Socket Connections (new menu item with this assertion) :
<Please see attached file for image>
And create an inbound assertion called :LFSocket". Under the general settings tab we set it as an Inbound socket, and the Data Protocol being a terminated message :
Under the Inbound settings tab we indicate which socket to listen on 8888, and which policy will be triggered to handle the request.
On the Protocol Settings tab, we indicate that 0a (lf) is the message terminator character to be used :
We then create the following policy which is triggered for any message arriving on port 8888.
In the policy we are just doing simple things, logging the ${request.mainpart}. Validating the Content-Type (which is the step we need to add), and then returning a template response.
