WPs do not start - U00011850 Record 'LSSYNCED' not found in table MQLS or does not match the Server version
Article ID: 110897
CA Automic Workload Automation - Automation Engine
The Automation Engine is not starting after an upgrade.
The Worker Processes (WP) are ending abnormally due too the error:
U0001850 Record 'LSSYNCED' not found in table MQLS or does not match the Server version.
Server will be terminated abnormally. Please start in cold mode
Cold Start does not help.
WP crash when no LSSYNCED record could be found in MQLS
Release: 12.3
Component: AUTOMIC AUTOMATION
- truncate table MQLS
- Cold start the Automation Engine
