CA Automation Engine V12.2 - U00005123 Program error: Purpose 'UCUVAR: col-value1 ' allocates memory with size zero
Article ID: 110081
CA Automic Workload Automation - Automation Engine
The following message appears in any Worker Process Log (WP log) during the Startup of the CA Automation Engine Version 12.2. The Messages do not cause any issues.
U00053200 Memory for 'UCUECS ' successfully allocated. Length = '316624'
U00005123 Program error: Purpose 'UCUVAR: col-value1 ' allocates memory with size zero.
