Step 31 of the install process copying the files YEDTCDERFP, YAUOOPT, and YMDLPRFRFP.
Step 31 of the install says
Consult your CA 2E application developers to determine which user-defined records need to be retained from the files YEDTCDERFP, YAUOOPT, and YMDLPRFRFP.
what does this mean? How would you determine which records you need to copy over from each one of the following files? YEDTCDERFP, YAUOOPT, and YMDLPRFRFP.
AS400 IBM Iseries
*How would you determine which records you need to copy over from each one of the following files? YEDTCDERFP, YAUOOPT, and YMDLPRFRFP.
Compare their saved copy with our new shipped version from 8.7 If they know they didn't alter anything then there's nothing to do, they can just use the 8.7 version
