MAX OBJ ID IN IEF.TRAN FILE < THAN MAX OBJ ID IN SUBSET ID TABLE
Article ID: 109034
CA GenCA Gen - Build ToolCA Gen - Workstation ToolsetCA Gen - Host EncyclopediaCA Gen - Run Time Distributed3RD PARTY TSO
Getting this upload error Beginning batch upload: Model = Model Name Subset = Subset Name Batch upload was unsuccessful. See LOGFILE for details. END OF TIEUP PROGRAM TIEUP: MAX OBJ ID IN IEF.TRAN FILE < THAN MAX OBJ ID IN SUBSET ID TABLE. TRAN MAX = 1 SUBID MAX = 1902641153 TIEC052E SYSTEM ERROR: SUBSET MAX OBJECT ID 1 INVALID. CONFLICTS WITH OBJECTS CURRENTLY IN THE ENCYCLOPEDIA. TIEUP: ROLLBACK PERFORMED TIEUP: TRANFILE BYTE COUNT = 130 TIEUP: TRANSACTION NUMBER = 1
Release: Component: CGHE
The error indicates that the subset has run out of object ids. Unfortunately you will either have to override checkout and redo the changes OR gen new model, adopt, and migrate the changes. This is a rare error. To help avoid it in the future, upload with or without check-in daily or with check-in weekly if a model/subset is checked out for an extensive period of time. Of course it can happen when the subset has been checked out for as little as 2 hours so it does vary.
