Compound threshold rule using 2 metric families in NetOps Portal
Article ID: 108955
CA Performance Management
Is it possible to create a threshold monitoring rule that requires two conditions be met using two different metric families? For example, if real memory exceeds 80% utilization and virtual memory exceeds 80% utilization then produce a threshold violation event.
Release: 22.2 23.3
yes, the NetOps Portal has the ability right now to create a threshold monitoring rule that requires two or more conditions be met using two different metric families.  Conditions are accessed using AND logic.
https://techdocs.broadcom.com/us/en/ca-enterprise-software/it-operations-management/performance-management/22-2/building/configure-threshold-profiles.html
