Vantage Problem with BVIR-Data after VTS MC-LVL Update
Article ID: 108244
Vantage Storage Resource Manager WatchTower WatchTower Platform
For IBM VTS tape library TS77xx:
 Library using microcode level 8.41.200.113 creates new version
 of HISTORICAL STATISTICS Records type x'30' and x'32'.
 SYMPTOMS:
 When you execute Vantage objects
  (VISIVTHH) IBM TS7700 Hnode HSM History
  (VISIVTHL) IBM TS7700 Hnode Library History - TDU
  (VISIVTH2) IBM TS7700 Hnode Library History - CSP
  (VISIVTH3) IBM TS7700 Hnode Library History - GUP
  (VISIVTH4) IBM TS7700 Hnode Library History - GUP MT
 you see pop-up window:
  Incorrect input data
 You can find two error messages in the Vantage log:
 for VISIVTHH
  OBJCVTHH UNSUPPORTED VERSION 07 OF BVIR HISTORICAL STATISTICS RECORD 30
  OBJCVTHH Incorrect input data
 for VISIVTHL, VISIVTH2, VISIVTH3, VISIVTH4
  OBJCVTHx UNSUPPORTED VERSION 06 OF BVIR HISTORICAL STATISTICS RECORD 32
  OBJCVTHx Incorrect input data
Release:
Component: VANT
APAR ST04310 written and provided to client. The APAR has following requisites: PRE( RO84906 RO88960 RO92145 ).
Please call CA Technologie  support to provide the test apar.
