Quick Edit not using ENDICNFG Element Layout default
Article ID: 106883
CA Endevor Software Change Manager (SCM)
CA Endevor Software Change Manager - Natural Integration (SCM)
CA Endevor Software Change Manager - ECLIPSE Plugin (SCM)
CA Endevor Software Change Manager - Enterprise Workbench (SCM)
Show More
Show Less
The UI_OPT_ELEMENT option in ENDICNFG has been set to S - short, but the Quick Edit panels uses the Long format. We have to go into the Quick Edit Defaults panel - ENDIEO00, and manually change the Layout from L to S.
Endevor V18 INC 12
Apply PTF SO04496
Feedback
thumb_up
Yes
thumb_down
No
