Problem with IIB10 fieldpack - no data reported in investigator
Article ID: 106050
CA Application Performance Management Agent (APM / Wily / Introscope)INTROSCOPE
This relates to the IIB10 FieldPack. The IIB agent starts and looks to connect to the IIB10 broker. The broker appears in the workstation,however there are no metrics reported and there is the following FATAL error in the agent log
7/06/18 10:55:42 AM BST [FATAL] [com.wily.powerpack.websphereMQ.agent.MQMonitor.MBMonitor.v7.MBTreeConfigMain] Broker BROKERNAMEHERE broken connection!
Problem was due to not having set the MQSI_CMP_USERNAME and MQSI_CMP_PASSWORD variables
IIB 10 Fieldpack
As per the IIB Fieldpack readme
If Admin Security is enabled, then to set the username and password using below System environment properties MQSI_CMP_USERNAME=username MQSI_CMP_PASSWORD=password
