Conversion from CA Vision and CA Vision DB2 to CA Easytrieve
Article ID: 105988
CA PanAudit PlusCA Easytrieve Report GeneratorCA PAN/SQL
Is there any information and/or documentation on what's required to migrate from CA Vision and CA Vision DB2 to CA Easytrieve? Is there any conversion tool?
Release: Component: EZTRVE
No, there are no guidelines or tools to migrate/convert from CA Vision/CA Vision DB2 to CA Easytrieve Plus. Each report and each process would have to be examined.
