The resolution to this issue comes in three parts.
(1) Install
FIX:RO96348 (incorporating Server_15.20_HF075, Server_x64_15.20_HF076, Client_15.20_HF077and Client_x64_15.20_HF078) This fix is available to download from the CA Support Portal (
http://support.ca.com)
(2) Microsoft has released a fix to address the memory leak issues identified during the conversion of Rich Text (RTF) to Unicode on Windows 2012 R2 machines.
https://support.microsoft.com/en-us/help/4041685(3) Install CA Data Protection 15.2
FIX:SO04070 (incorporating Server_15.20_HF0183, Server_x64_15.20_HF0184 and Client_15.20_HF0185). This fix is available to download from the CA Support Portal (
http://support.ca.com) and includes the following binaries:
client\wgnsm.dll - 15.20.4645.0 - 4-Jun-2018
client64\wgnsm.dll - 15.20.4645.0 - 4-Jun-2018
