Trying to do a filter with 2 values one of this is numeric type but it has decimals, the foundation filter only allow enter integer values. Replaced field with the specific field, but when click "insert" the criteria grid takes other value. This entity has two fields AAAAAA is the key, this key is type quantity length 4 and the second field BBBBBB ,is numeric type but with a length 21 and 9 decimal places.Problem is when I have attributes with decimal places. It's impossible write in the filter because only allow integer when is numeric type
it's impossible write in the filter because only allow integer when is numeric type
Windows 10, our DBA is AS400 r 7.2.1, Plex 7.2.1 build 24000
You need to check your field definitions if they are valid. In this sample the reason for the problem is field replacement with "Replacement field ", inherited from field which is not compatible with C++ variant. To overcome this problem,,create a new field.
